  • 175 Pages +
  • 14
  • 15
  • 16
  • 17
  • 18
#301 L'utilisateur est hors-ligne   Petz
  • Inscrit(e) : 25-mai 08
Posté 25 mai 2008 - 15:38
@ crapouillo !
Sorry that i have to write in english but i unfortunately don´t speak french, i hope you can understand that too; an online translation would makes less sence for posting this special themes - maybe someone of the other members would be so kind to do a sinful translation here.....
First i have to set a big big big compliment when just have seen your cableways and lifts; there are only a few specialists reaching your quality !!!
Want to tell you my idea producing the rope clamps, maybe it could be sinful for your purpose too. I use this kind of clamps since 2002 for outdoor model lifts, my first lift had run more then 8000 hours until now with this clamps - now it would be time to change them out......
I use another type of electric clamps as basis:
The older clamps had been made from brass, the newer ones are from nickel plated steel sheet metal but that makes no difference. After stripping it from the plastic first i cut them up.
For the more simple model you have to bent them and partially cut it in length direction:
The more complicated version i show here, they get solded a piece of wire on the upper side for passing the depression towers.:
Grinding the clamps exactly based on the contour of my self lathed wheels the two point supporting when passing the wheel guarantees a smooth and oscillating free passing of the sheave batteries.
Another possibility is the modelling of the american "Riblet" clip which is inserted inside the rope, this guarantees the smoothest running but the rope had to be turned open between two pliers to insert every clip:
Also a detachable model is possible at this basis.
This had been my variant of a divided (for easier shipping) zinc plated steel tower for a LGB - cableway....
More infos and pictures (from other builders too) are shown at my homepage, if you are interested you can find the URL im my profile.
Kind regards, Markus
Ce message a été modifié par Petz - 26 mai 2008 - 20:11 .
Désolé pour signaler en anglais ou la traduction en ligne mais malheureusement je don´t parle français .....
#302 L'utilisateur est hors-ligne   crapouillo
  • Inscrit(e) : 13-octobre 07
Posté 25 mai 2008 - 21:33
Thanks Markus, I'm very proud to see a specialist and important member of the "AlpinForum" here. I'll wrote also in english (not a very good one, sorry) because in don't speak German ;) . But Iknow the Alpinforum and Funivie (i'm a member...but i don't speak italiano ;) ).
I' also use electric clamp for my chairlift but not the same that yours:
What's mecanism do you use for your detachable rope clamp? Do you have anothers pictures.
(trad: Merci Markus, je suis trés fier de voir un spécialiste et un memebre éminant de l'ALPINFORUM ici. J'écrirai également en anglais (pas trés bon, désolé) car je ne parle pas Allemand. Mais je connais l'Alpinforum et Funivie (j'en suis membre...mais je ne parle pas Italien).
J'utilise aussi des dominos electriques pour mon télésiège même s'il ne sont pas identique au tiens).
Sinon, ce WE j'ai reprofilé la piste rouge que desservira le télécabine et j'ai soigné un peu mon décor (comme conseillé par Karott) avec pierre et rondins pour soutenir le terrain. J'ai également effectué un "paillage" de la piste avec le fruit de la tonte du Gazon. Celà évite le ruisselement.
Et voici le vallon où sera implantée la G1, on remarque le piquet matérialisant l'axe de la ligne:
Je pense débuter le fondation de la G1 d'ici début juin mais la météo devra etre plus sèche car aprés une nuit de pluie, c'est la gadoue :D
Sinon, j'ai quasiemment terminé mon plan commun pour les G1 et G2, je vais essayer de le photographier pour vous le présenter...
#303 L'utilisateur est hors-ligne   tcd4_spielboden
  • Inscrit(e) : 02-mars 07
Posté 27 mai 2008 - 15:31
Wouaou, quel travail titanesque !
Je me réjouis de voir cette G1 !
Bonne continuation.
#304 L'utilisateur est hors-ligne   titusdu42
  • Inscrit(e) : 16-mars 08
Posté 27 mai 2008 - 16:11
euh... ayant un grand terrain je suis un spécialiste de l'herbe (MMDDDDRRRRRRR (rire)) et donc je préfère te prévenir, même si je pense que tu t'en doute, que très rapidement l'herbe coupé va pourrir et deviendra ainsi très vite moche et malodorante...
Sur ce je prend toujours otan de plaisir à te lire!
bonne continuation
#305 L'utilisateur est hors-ligne   lux
  • Inscrit(e) : 04-mars 08
Posté 27 mai 2008 - 16:31
Magnifique cabine! ;)
Bravo, j'attends la suite avec impatience! :D
#306 L'utilisateur est hors-ligne   Petz
Posté 27 mai 2008 - 18:45
Voir le messagecrapouillo, le 25 05 2008, 22:33, dit :
Thanks Markus, I'm very proud to see a specialist and important member of the "AlpinForum" here. I'll wrote also in english (not a very good one, sorry) because in don't speak German :D . But Iknow the Alpinforum and Funivie (i'm a member...but i don't speak italiano ;) ).
Thank you very much for your warm welcome, like to correspond with other great model lift builders.
I´ve tried your type of electric clamp at the beginning too but for my purpose they are a bit too delicate cause i want to cut them up to have the possibility to set and remove a chair very simply from the rope; so i have to use the bit stronger type.
You´ll get a personal message about my detachable model; i hope you understand that i don´t want to post detailed pictures of it open.
If somebody is interested in i have uploaded a short videoclip where you can see a part of the lift filmed with a spycam situated in one of the "baskets". Chief Paolo from funiforum.org has done the compression for me so don´t wonder if you see the logo at the beginning.....wmv type, 2,39 mb.
http://members.aon.a.../petz_linea.wmv
Ce message a été modifié par Petz - 27 mai 2008 - 18:51 .
#307 L'utilisateur est hors-ligne   crapouillo
Posté 27 mai 2008 - 21:38
Voir le messagePetz, le 27 05 2008, 19:45, dit :
Thanks Markus, I'm very proud to see a specialist and important member of the "AlpinForum" here. I'll wrote also in english (not a very good one, sorry) because in don't speak German :( . But Iknow the Alpinforum and Funivie (i'm a member...but i don't speak italiano :) ).
Thanks for the video and you're wonderfull detachable clamp pictures: The only problem is that the scale is a little too large for my purpose :) . But my clamp is also detachable but without any moving piece.
You're right, My clamps remain on the slope all the time but i can remove the chairs.
Sinon, merci à tous pour les compliments et désolé pour ces petits passage en langue de shakespear, mais c'ètait çà ou l'allemand :lol: .
Concernant ce que dit Titus, ben tu as tout-a-fait raison, l'herbe va jaunir et se décomposer peu à peu mais l'épaisseur étant trés faible pas de problème de pourriture et d'odeur (j'ai dejà fait un essai il-y-a 3 semaine). Celà donne un couche de foin bien collé au sol par la pluie qui évite les ruiselement et les "giclures de terre" sur mes pylones et surtout galets et poulie;avec une pluie d'orage on peut se retouver avec de la boue jusqu'à 30cm de hauteur et les axes des galets détestent la boue séchée qui reste collée à la graisse et qui bloque tout.
C'est le type de détails qu'on découvre avec le temps...
Sinon, le plan (simplifié) de la G1 est terminé je posterai une photo trés vite
#308 L'utilisateur est hors-ligne   ScaN
  • Inscrit(e) : 28-mai 08
Posté 28 mai 2008 - 10:16
Bonjour bonjour,
Je suis tombé un peu par hasard sur ce site, et je viens de lire ce post de la page 1 jusqu'au dernier message. Crapouillo, je ne vais pas être très original, mais c'est du très beau travail !! C'est vraiment magnifique, j'ai eu l'impression de revivre de rêves gosses.
Une telle patience pour une telle précision, qualitée, chapeau :)
Bonne continuation pour la TC :)
#309 L'utilisateur est hors-ligne   val cenis 77
  • Inscrit(e) : 14-novembre 07
Posté 28 mai 2008 - 18:02
Salut !
Mais les gare et pylones du tk et du tsf ne risques pas de s'abimer avec le temps !! :)
Sur ce ; bonne continuation ! :)
#310 L'utilisateur est hors-ligne   titou_love_valto
  • Inscrit(e) : 05-juillet 07
Posté 28 mai 2008 - 18:36
tu sais l'alu tiens assez bien en extérieur se qui craint le plus c'est les éblaboussures de boue (comme la fait remarquer crapouillo avec son herbe!! :) ) sinon faut faire attention a faire tourner souvent pour les moteurs c'est tout!!
#311 L'utilisateur est hors-ligne   Petz
Posté 28 mai 2008 - 20:56
Voir le messagecrapouillo, le 27 05 2008, 22:38, dit :
My intention had been to develope a detachable clamp which automatically could be removed and set to the rope in the stations, based on this reason i tried the excenter type; but unfortunately i see hardly a chance to build this version in a much smaller scale.
Some years ago i built a more simple prototype of a gear wheel type detachable clamp following system Müller for a swiss alpinforum member; maybe you could try a version in a bit smaller scale based on your type of electric clamps maybe with N - scale cogwheel model railway parts (Fleischmann for example).
#312 L'utilisateur est hors-ligne   KoUiToU
Posté 28 mai 2008 - 21:30
Val Cenis 77 tu peux très bien utiliser du meccano pour construire une remontée à l'exterieur, simplement tu prends une bombe de peinture galva et tu protège toutes tes pièces.
#313 L'utilisateur est hors-ligne   Petz
Posté 29 mai 2008 - 18:12
Voir le messageKoUiToU, le 28 05 2008, 22:30, dit :
Ou on a ne une possibilité bon marché de galvanisation comme heureusement moi.
#314 L'utilisateur est hors-ligne   KoUiToU
Posté 29 mai 2008 - 19:26
Pour de la galva, içi ou içi.
#315 L'utilisateur est hors-ligne   crapouillo
Posté 29 mai 2008 - 21:00
Pour mes remontées j'utilisait de la peinture haute temperature de chez LEROY MERLIN mais vous m'avez donné une idée. Je vais essayer la galvanisation à froid pour mon télécabine, çà sera plus conforme à la réalité:) . Enfin, on n'en est pas encore là...
Comme promis voici la photo de mon plan échelle 1 de mes gares. Comme vous pouvez le voir ce n'est pas un plan qui présente tous les détails de fonctionnement, ceci pour deux raison:
-C'est moi qui conçois et fabrique donc je n'ai pas besoin de tout représenter
-pour certaines parties (trains de pneus et lorry) je ne sais pas encore précisemment ce que je vais utiliser...
Sinon, ce week-end je vais remplacer la toiture de la G1 du télépherique (le contreplaqué gondole). Poursuivre la construction de la station et débuter la G1 du télécabine (en Atelier, vu le temps...)
#316 L'utilisateur est hors-ligne   lux
Posté 30 mai 2008 - 09:14
Superbe plan on dirait un vrai!:)
#317 L'utilisateur est hors-ligne   firoclem
Posté 30 mai 2008 - 10:26
Crapouillo cette cabine est magnifique et super réaliste ! Encore une fois CHAPEAU BAS pour ton imagination...
J'allais te proposer d'assembler des plaques d'altuglass ou autres composite transparent tels les sous verres d'encadrement mais l'idée des porte crayons bleus est géniale !
Je voulais poster qq photos de mes cabines concues sur la base toute simple du développé d'un cube (en cartoline 320gr/m2) mais n'ai pas réussi à attacher des images à ce message - de toute façon on sortirai de ce super post
Tous mes encouragements pour cette future TC.... que j'ai hâte de voir en circulation :)
#318 L'utilisateur est hors-ligne   firoclem
Posté 30 mai 2008 - 10:54
Voir le messagelux, le 30 05 2008, 10:14, dit :
Lux, Je viens de voir ta video et ton blog et je tiens à te féliciter tout autant pour la réalisation de ton "plus grand TS miniature", et saluer ta passion comme il se doit. Tu as tout du petit génie et je suis sûr que tu nous feras toi aussi des plans aussi beaux que ceux de Crapouillo
Un grand salut de passioné à toi
ps: j'aimerai bien savoir comment poser des photos sur ce forum... suis-je Idiot total ou c'ets encore une histoire de droits et accréditations... lol
#319 L'utilisateur est hors-ligne   snowboarder
  • Inscrit(e) : 17-novembre 06
Posté 30 mai 2008 - 12:25
Voir le messagefiroclem, le 30 05 2008, 11:54, dit :
Aucun besoin de droits pour pouvoir mettre des photos, regarde là tu trouvera la réponse :
http://www.remontees-mecaniques.net/forums...?showtopic=1319
#320 L'utilisateur est hors-ligne   firoclem
Posté 30 mai 2008 - 18:24
Voir le messagesnowboarder, le 30 05 2008, 13:25, dit :
Ahh ! partis tout droit dans les modèles réduits, j'ai loupé de lire les lignes importantes
Merci snowboarder
  • 175 Pages +
  • 14
  • 15
  • 16
  • 17
  • 18
1 membre(s), 1 invité(s), 0 utilisateur(s) anonyme(s)
  1. Samy93
